Newbie
Message 1 of 4
Internet Disconnecting And Reconnecting
Does anybody know how to fix Internet Disconnecting And Reconnecting because all the time when I play games on my pc or something like that every 20 mins or something it disconnects then reconnects again
3 REPLIES 3
Message 2 of 4
Re: Internet Disconnecting And Reconnecting
are you using wifi or ethernet?  is it the hub that is dropping internet connection - lights changing from blue - or is it you wifi connection that is dropping
post hub stats  if hh5 then troubleshooting then helpdesk   if hh6 then advanced settings then technical log information
any line noise   dial17070 option 2  should be silent and best with corded phone
Newbie
Message 3 of 4
Im using wifi from my pc so im not sure if its my pc or the router
Recognised Expert
Message 4 of 4
@imjolly asked you if you can let us know if the router lights change colour during the time your connection drops.
