MatthewG-
Message 1 of 7
Internet Download Speed Dropped
I have had intermitent connection issues before but they cleared up for around 2 years today it the first time it dropped out in a while but my Download Speed got dropped due to Interleavering, Any Advices on what to do?
before.pngBefore Disconnection (Old Photo)
After.JPGAfter Drop Out
Message 2 of 7
Re: Internet Download Speed Dropped
have you checked your line for noise by doing quiet line test?
the interleaving depth has reduced
your attainable has reduced and connection speed is currently about attainable  do you know if there has been other recent disconnections apart from the one in last hour
MatthewG-
Message 3 of 7
The logs only go back as far as to Feb 8th midday and there is no drops between then apart from today Smiley Sad
I have also done a Quite Line test and it clear
Also More info regarding Cabinet
MatthewG-
Message 4 of 7
@imjolly
I have just check my Router Firmware and it seems to be quite out of Date v1.10.03 build398 Jul. 17, 2017 should I update the Firmware or will it affect the DLM process?
It is several builds out of date but there is a lot of fixes regarding xDSL Drivers
https://www.asus.com/uk/Networking/DSL-AC88U/HelpDesk_Download/
Message 5 of 7
as the router dropped conenction only few hours ago I would wait couple of days and then update the firmware to current version
at present your connection speed is within estimated range and above handback speed so unless there is a fault BT won't help getting faster speed
MatthewG-
Message 6 of 7
@imjolly
I saw your post but after a bit of reserch and reading the update logs there was alot of feature added like Support for G.INP and a lot of fixes for xDSL and software bugs
Well I am hoping the Update just fixed my issue
It appers that G.INP is active on my line and I am now on Fast Path insted of interleavered updated.JPGAlso should My WIFI 5Ghz be that hot ?
MatthewG-
Message 7 of 7
Update:
Within the new updated firmware it added FEC the router has only been up 12 hours and FEC is keeps  clocking up
FEC downstream is 210000+ upstream 4
CRC, HEC, ES and SES are at 0
