Message 1 of 5
Internet Issue
1st Jan 24 - Anyone having internet issues in Skipton, Broughton Rd / Morrison’s area ?
4 other residents in my apartment block also have no internet. I have a spare router, my hardware is fine.
thanks
4 REPLIES 4
Message 2 of 5
Re: Internet Issue
Hello @Martin26
This sounds like an MSO (Major Service Outage).
You can do some diagnostics by clicking HERE.
This will tell you if any fault has been found and if you require an engineer etc.
Hope this helps! 🙂 If you like my reply and
want to say thanks for the helpful answer
then please click on the Kudos on left hand
side 😉 also if I answers your question correctly please let us know by clicking on Mark as Accepted Solution 😄
Message 3 of 5
Re: Internet Issue
Cheers Fizzylp, fantastic help
Message 4 of 5
Re: Internet Issue
Not a problem! Did the diagnostics show as an MSO? If so did it say the exacted time frame was to resolve?
Message 5 of 5
Re: Internet Issue
Yes it did, by 5pm on the 2nd Jan
