Techwizz
Message 11 of 39
Re: Internet Speed Dropped after Disconnection
That speed is shocking for the attenuation, definitely a fault there.
Distinguished Guru
Distinguished Guru
Message 12 of 39
@imjolly wrote:
@pippincp
Can't be as I copied your  post from a previous time and use it😂😂😂
That's an old one. Try this.
Distinguished Guru
Distinguished Guru
Message 13 of 39
Ring in and request an engineer. You may have to insist, don't take anything else as a solution.
Duncandisorderly
Message 14 of 39
The line is silent. I don't think there is a problem with then internal wiring as earlier in the month I was getting the higher speed consistently. Nothing internally has changed, and I only saw the drop in speed from the reinstatement after the external issue.
Message 15 of 39
Well from the stats you have posted there is something wrong with your connection and it is either internal or external. To endure that you don't get charged £85 fir engineer visit trying the test socket with a filter is the best way. If that does not help speed and improve stats then as suggested you need to phone 151 and get engineer visit
Moderator
Moderator
Message 16 of 39
Hi @Duncandisorderly,
Please can you try the test socket as suggested by @imjolly and @pippincp. If you don't notice an improvement after that post back and I'll be more that happy to take a look at your connection and run a few checks on your line.
Its important that we rule out any internal issues first in case we need to send an engineer.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
Duncandisorderly
Message 17 of 39
I used the broadband fault finder late last night. It reported slow speed. It then did further checks on the network and reported a fault outside my property. I have had an email this morning saying they hope to have it resolved by 6 pm 21/02/19. There were no visible details of what the fault was, just that it was outside the house. I assume this already discounts the internal set up which hasn't changed. There was no suggestion the engineer needed access to my property, so presumably they can see the fault is external.
Hopefully it will be resolved as indicated and I'll be back to normal soon.
Thanks for your support.
Moderator
Moderator
Message 18 of 39
Thank you for posting back, please let us know how things go on the 21st?
PaddyB
Kudos”Kudos”
Message 19 of 39
If as I suspect nothing will change after 21st then try test socket with filter as previously suggested
Duncandisorderly
Message 20 of 39
If nothing changes after 21st. I'll do as you say. I didn't expect the result returned last night, but as it appeared to show an external fault I don't mind giving it a couple more days. I guess I'll either be back in a couple of days to say problem solved or to report what I see with the filter at the master socket. Your lack of optimism is presumably based on long experience. Food for thought.
