Duncandisorderly
Message 31 of 39
Re: Internet Speed Dropped after Disconnection
Further to your call earlier this evening, I borrowed a corded phone from my neighbour and substituted this for my own. I can't tell any difference. There are occasional crackles on the line with either. With the corded phone connected, the router reconnects with the same sync speeds i.e 21.59/3.69 Mbps.
Techwizz
Message 32 of 39
If you're getting crackles in the test socket, then you need a telephony engineer.
Distinguished Guru
Distinguished Guru
Message 33 of 39
I'm sure the mods will organise whichever engineer is needed.
Community Manager
Community Manager
Message 34 of 39
Hi @Duncandisorderly  I see the engineer has referred this on to a different team to arrange for the necessary dig work to be completed. I will continue to monitor the progress of this fault and keep you posted.
Community ModeratorStephanie
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Duncandisorderly
Message 35 of 39
The engineer ran tests internally and externally from my property, and established there is a fault on the line approximately 13 metres away. This is at or about the location of the recent severence and repair. He then checked upstream at the nearest junction box which is the other side of the where the cable was cut. He said from there back to the cabinet appeared clear, but downstream from the JB towards my property still showed the fault. I believe he feels the likely cause is the recent cable repair. He said he would request the dig team and get them to check and if necessary remake the joint. Hopefully this will solve the problem.
Distinguished Guru
Distinguished Guru
Message 36 of 39
Thanks for updating us.
Duncandisorderly
Message 37 of 39
The Open Reach guy excavated the recent cable repair with the guy who originally cut the cable and repaired it. He was not happy with the repair, and replaced a section of cable with new. He terminated the new cable and then came to my house to check the line. The phone was fine and the broadband reconnected first time with speeds as below.
Downstream sync speed: 29.15 Mbps
Upstream sync speed: 5.07 Mbps
Obviously the original repair up the road was causing the problem. At my location I was promised 30-35 Mbps, and we are now close to that and pretty much back where I was before the accidental line damage three weeks ago.
Duncandisorderly
Message 38 of 39
One thing I would point out is that BT seem to be reducing the expected speed for the "Up to 55 Mbps" service at my location. When I originally switched to fibre to the cabinet I got close to 35 Mbps. A year or so back when I was encouraged to take the newer home hub, I was promised 30-35 Mbps. I then got slightly below 30 Mbps. tonight looking at my offers I'm encouraged to take "Superfast Fibre Plus
Your download speed range 29Mb - 44Mb
Upload speed range 5Mb - 7Mb
Your minimum download speed 28Mb"
Unless I'm missing something my minimum download speed is reducing over time as I'm encouraged to pay my for another service.
Community Manager
Community Manager
Message 39 of 39
Hi @Duncandisorderly good speaking with you there. I'm happy to see that your connection is now stable, and that there's no more noise on your line.
Please post back if you need us to look into your connection further in the future.
Kudos”
