scottwadeson
Message 11 of 11
Re: Internet connection dropping
Can anyone help with this?
I'm confident that there is a problem with the broadband supply, as all the wires and hub have been replaced numerous times.
Every time I restart the hub the internet doesn't drop for an hour or so, which makes me think getting a BT engineer round won't help as they will think the problem is solved after trying the first thing out.
