sjjenner
Message 1 of 2
Internet connection drops in the evenings
Hi there,
I am encountering a problem where my internet connection drops a number of time each evening.I wonder if anyone can give me advise. I've followed the steps of ensuring the 2.4 and 5 GHz SSIDs are different etc. but the disconnections still occur.
Below is a segment from the event log for the last disconnection.
17:14:14, 11 Jan. (85397.850000) CWMP: session closed due to error: No response
17:14:14, 11 Jan. (85397.810000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
17:14:14, 11 Jan. (85397.800000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
17:14:14, 11 Jan. ath00: STA 00:21:6b:ae:12:fe IEEE 802.11: Client associated
17:14:14, 11 Jan. ath00: STA 00:21:6b:ae:12:fe IEEE 802.11: Client disassociated
17:14:02, 11 Jan. (85386.370000) PTM over DSL is up
17:13:43, 11 Jan. (85367.370000) CWMP: session closed due to error: No response
17:13:41, 11 Jan. (85364.650000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
17:13:41, 11 Jan. (85364.640000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE'
17:13:40, 11 Jan. (85364.220000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
17:13:34, 11 Jan. (85357.750000) PTM over DSL is down after 1421 minutes uptime
17:13:34, 11 Jan. (85357.750000) PPPoE is down after 1420 minutes uptime [Waiting for Underlying Connection (WAN Ethernet 2 - Down)]
17:13:31, 11 Jan. (85354.990000) OpenWiFi IPSec connection is down
17:13:28, 11 Jan. (85351.540000) PPP LCP Send Termination Request [User request]
17:13:05, 11 Jan. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1 xxx.xxx.xxx.xxx- >xxx.xxx.xxx.xxx on ppp3)
17:13:02, 11 Jan. BLOCKED 1 more packets (because of ICMP replay)
17:13:02, 11 Jan. OUT: BLOCK [7] ICMP replay (ICMP type 3 code 1xxx.xxx.xxx.xxx- >xxx.xxx.xxx.xxx on ppp3)
1. Product name: BT Home Hub
2. Serial number: +068343+NQ53209901
3. Firmware version: Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 13/10/15
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 00:05:56
6. Data rate: 1997 / 20205
7. Maximum data rate: 2421 / 20522
8. Noise margin: 6.0 / 6.3
9. Line attenuation: 37.0 / 31.0
10. Signal attenuation: 37.3 / 26.5
11. Data sent/received: 745.5 MB / 10.3 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4 GHz Wireless network/SSID: BTHub5-RKTK
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID: BTHub5-5G
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address:xxx.xxx.xxx.xxx
24. Modulation: G.993.2 Annex B
25. Software variant: AA
26. Boot loader: 1.0.0
PS: This didn't happen when I had the seperate infinity box and wifi just. Just started with the move to HH5.
(I've remove any specfiic address info).
1 REPLY 1
Message 2 of 2
Re: Internet connection drops in the evenings
The events are due to BT updating the firmware/configuration of the hub. Possibly repeatedly due to lack of success. You could try a factory reset of the hub, seems to cure a lot of ills.
