Grekovic93
Message 1 of 37
Internet drops several times everyday
This is happening from a long time.
I'm a tenant of a share house and we have BT Infinity 2. We use to have 60/20 but lately we had 15/3 and sometimes internet drops.
So I contacted BT by chat and an engineer came last Saturday. He changed a socket because the one we had it was very old. So after that he asked me to do a speedtest and we had 50/20. After one hour internet starts to drop from that day till today I don't know how many times happened ( orange led and the B led orange as well).
I read some posts in here and people found a solution changing the router so I don't know. I hope someone can help me
36 REPLIES 36
Message 2 of 37
Re: Internet drops several times everyday
Welcome to this user forum.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Grekovic93
Message 3 of 37
Thanks for reply. We don't use phone we just have broadband. I will get one today and I will try later after work.
I will write around 6pm
Message 4 of 37
A noisy phone line is the most common cause of disconnections. This cannot normally be detected by the BT line test.
Grekovic93
Message 5 of 37
Hello. I did the test and no noise. The voice said fine line test.
Message 6 of 37
Are you sure as the announcement normally only says quiet line test. Did you use a corded phone
have you tried using test socket with a filter?
Grekovic93
Message 7 of 37
Yes it says quite line test and no noise. I'm using a cordless phone. Thanks
Message 8 of 37
XNormally with cordless phone you get a dull hum on quiet line test
are you using test socket with a filter to see if that helps
Grekovic93
Message 9 of 37
No I'm using the master socket 5c. Internet now is ok with blu led.
Message 10 of 37
If it starts to drop again then try test socket by removing fron of 5c and test socket is now visible
