spock999
Message 11 of 14
Re: Internet goes down - only comes back when I restart my home Hub
OK. I have done the factory reset. As you say not as major a deal as I had thought!
Of course, now I need to wait a while (48hrs or so!) to check that all remains OK. If it remaisn OK I will come back and mark it as the solution.
Thank you for your assistance.
Message 12 of 14
See how it goes. The problem with firmware upgrades, is that there may be changes in the configuration file which are needed by the new firmware. By doing a factory reset, you load the default configuration that goes with that firmware.
Many router manufacturers recommend a factory reset after a firmware upgrade, to avoid such  issues.
spock999
Message 13 of 14
I can see that. However, when the update occurs automatically overnight how are you to know when it is necessary? Only when it goes pear-shaped!!
Hopefully it is better now and as you say we shall see.
spock999
Message 14 of 14
All OK after a week so it looks like that sorted it.
Thank you.
