Message 11 of 16
Re: Internet keeps cutting out.
Okay, that’s understandable. Too be fair my Internet has been working fine ever since it was fitted. Just all of a sudden the past few days we had the drop outs. I have also done some speed tests and noticed the download speed had dropped from 72.00 mbps to around 30-50 mbps. Upload was fine and still hitting 19-20 mbps.
Message 12 of 16
If the extension was run from the correct place, then it will be connected to the terminals on the back of the removable bottom section of the master socket.
Oxidisation can occur on the tiny spring prongs that connect the test socket to the bottom section, as there is no movement between them.
It would be worth unscrewing the bottom section and sliding it in and out a few times, or better still, use a contact cleaner fluid. It may stop the disconnections, and also restore the speed.
Message 13 of 16
My plan is to move back to the BT socket on the stairs when I get a plug socket fitted on there. But I will certainly try out the information you provided to see if this will rectify the issue. It will most likely be tomorrow when I try this out, I think it will be better to buy some contact fluid cleaner as you stated and give it a test.
Message 14 of 16
Servisol Super 10 is a good contact cleaner, its also very good at removing sticky labels as well.
Message 15 of 16
Will I be able to get it in pretty much any DIY store? Or a similar product. I’ll take a look in ScrewFix tomorrow or Wickes and ask the staff what they have in stock. Just googled the product you recommended and it had a really good write up.
Message 16 of 16
There may be other suitable stuff, but you have to make sure that its safe on plastics.
The actual contact area is quite small, and consists of a number of springy strips that make contact with the faceplate so you have to be careful not to damage them, or bend them out of shape.
You may find evidence of corrosion if the socket is situated in a damp place.
The wires to that extension should be visible on the back of the faceplate, as shown here.
Extension wiringExtension wiring
It may be worth checking that they are connected properly, and there is no corrosion.
It only takes a slightly bad connection to cause random disconnections and loss of speed.
