Message 1 of 2
Internet speeds when gaming
Hello all,
was looking for some help with my internet my speeds are 30 down and 7 up however when I’m using my pc connected via Ethernet my speeds are what one can assume as throttle.
example; I’ll have an update for a game say around 12gb and I’m stuck averaging around 3mb per second resulting in me being sat around for some time despite paying for the speeds above.
trying to find a solution to my problem especially as updates for games are increasing in size.
thanks.
1 REPLY 1
Message 2 of 2
Re: Internet speeds when gaming
@Will-c
Make sure you are not getting confused with Megabits and Megabytes.
Downloads are usually measured in MegaBytes/second. 3.75 is close to what you are getting, allowing for transmission overheads.
You can run a speed test here https://speedtest.btwholesale.com/ using an Ethernet connection.
