Message 1 of 6
Internet
My wifi starts on the 7th but I don't get my router till the tenth can I still use my old router till my new one comes
5 REPLIES 5
Message 2 of 6
Re: Internet
A lot more information is required.
By WiFi I assume you mean broadband. Are you moving to BT from another supplier?
Are you changing from copper to fibre?
What router do you currently have?
Message 3 of 6
Re: Internet
I'm moving to BT I was with SSE
Message 4 of 6
Re: Internet
When is your BT broadband activation date as unusual to get activation before receipt of hub
Message 5 of 6
Re: Internet
This is like pulling teeth.
What router do you currently have, is it locked down or can you configure it.
Message 6 of 6
Re: Internet
You say you are with SSE if you are using the router they provided I would imagine its locked down
If you are using your own then you can configure it with the details:
username [email protected]
Password: BT
You would normally get your router a few days before though so I would follow up with BT:
Track or change a new broadband order | BT Help
