Message 2 of 14
Is BT DNS down?
The only way I can get internet access is via 8.8.8.8 as my DNS.
The BT DNS seems not to be working.
13 REPLIES 13
Message 1 of 14
Why can't I get to microsoft support site from my BT broadband connection?
Attempting to get to the microsoft support site comes back with an "unable to connect" page (generated locally) suggesting a DNS problem.
I've tried flushing using ipconfig and restarted the PC - same problem.
Message 3 of 14
Re: Is BT DNS down?
Message 4 of 14
Re: Is BT DNS down?
Most of BT seems to be down so wouldn’t surprise me.
I can confirm that the “My BT” app is down. Also on down detector there’s over a thousand reports in the last hour (baseline is 25)
Message 5 of 14
Re: Is BT DNS down?
Looks like the service status page is also down.
It says it can't find my phone number.
Message 6 of 14
Re: Is BT DNS down?
I get that too.
Infuriatingly most of us have done away with our landlines which leaves us no way of checking the service status anyway as it requires a landline number.
Honestly I wonder if any of their staff have ever tried to use their systems
Message 7 of 14
Re: Is BT DNS down?
You're probably not missing anything.
They never say they have a problem especially when they do.
It's only by asking other customers (like here) that you find out it's not a local problem with your own PC or phone.
There is no understanding of (or care for) customers - no idea why. Perhaps it costs too much to care.
Message 8 of 14
Re: Is BT DNS down?
🔍 Current Status:
• BT DNS problems are being flagged by users across the UK, including in areas like London, Manchester, and Birmingham.
• The spike in reports suggests intermittent connectivity issues, likely linked to DNS servers not resolving domains properly.
• Some users are unable to access websites unless they switch to alternative DNS providers like Google DNS (8.8.8.8) or Cloudflare (1.1.1.1).
🛠️ What You Can Do:
• Change your DNS settings manually to a public DNS provider. This often bypasses the issue:
• Google DNS: 8.8.8.8 and 8.8.4.4
• Cloudflare DNS: 1.1.1.1 and 1.0.0.1
• Flush your DNS cache:
• On Windows: Open Command Prompt and type ipconfig/flushdns
When can I expect a paycheque from the Customer Service Department?
Message 9 of 14
Re: Is BT DNS down?
Of course you are just telling the people who already know how to change their DNS as they will be the only people to see it.
Message 10 of 14
Re: Is BT DNS down?
It's still more than BT have done!
For a Windows 11 PC:-
  1. Open Network Settings
  •            Right-click the Start button and select Settings
  •            Go to Network & Internet
  •            Click Ethernet (if wired) or Wi-Fi (if wireless)
  1. Access DNS Settings
  •            Scroll down and click Edit next to DNS server assignment
  •            In the dropdown, select Manual
  •            Toggle IPv4 to On
  1. Enter New DNS Addresses
  •            Preferred DNS:  8.8.8.8 (Google) or  1.1.1.1 (Cloudflare)
  •            Alternate DNS:  8.8.4.4 (Google) or  1.0.0.1 (Cloudflare)
  •            Click Save
  1. (Optional) Flush DNS Cache
  •            Press , type , then press Enter
  •            In Command Prompt, type:  and hit Enter
