matekaneve
Message 61 of 95
Re: Is BT limiting download speed?
Thanks John! Yes, I'll be away so hopefully within that time it will settle. Actually the speed went back to normal about 10-15 minutes ago again and seems stable again... I really don't know what's happening here... Could it be my "not so" smart hub or maybe my neighbours are doing something... 😅 Anyway I'll post an update in 2 weeks! 👍
zidder
Message 62 of 95
YES ! my speed has dropped from 50mbps to 44mbps. Ah yes but they say you now have guaranteed minimum.
Just more corporate manipulation
Moderator
Moderator
Message 63 of 95
Hi @matekaneve yes the SVLAN change over has happened and your connection is now in a stabilisation period for the next 9 days.  I would like to leave things as they are for now and we'll review things in a couple of weeks. If the SVLAN needs changed back I can request this.
@zidder I'm sorry to see you're not happy with your broadband speed. If you start your own thread and post router stats we'll be happy to take a look.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
matekaneve
Message 64 of 95
Thanks Neil!  I didn't know there is the 10 days period. We will see in 2 weeks than! 👍👍
matekaneve
Message 65 of 95
Good evening everyone! Unfortunately I have to bump this topic again as again I'm experiencing some ridiculous download speed in the last 2 days in the evening. Below my recent screenshots from tonight. @NeilO last time you helped me. Any idea? Thank you in advance!
pompey1898
Expert
Message 66 of 95
Hi @matekaneve ,
There is an error with the BT Speed test ( I get it regularly ).  As you can see it quotes an Upload Speed of 30.72 Mbps.
matekaneve
Message 67 of 95
Upload speed is wrong yes, but the download is what I got everywhere. In the last two nights my download speed was down again to between 20 and 30Mbps. My normal is 56-57Mbps and if you scroll back in this topic there are 7 pages about this issue I'm experiencing. It was after midnight when download speed went back to normal.
Moderator
Moderator
Message 68 of 95
Hi @matekaneve oh that's not good, I'm sorry to see this issue has returned. Could I ask that you send over your details again and we'll be happy to help?  I've sent you a Private Message with details on how you can get in contact with the mod team.
Kudos”Kudos”
matekaneve
Message 69 of 95
@NeilO Thank you for the quick reply! I sent the private message with all the necessary information.
Moderator
Moderator
Message 70 of 95
Thanks @matekaneve one of the mod team will be in touch in the next couple of days.
Kudos”Kudos”
