Message 11 of 12
Re: Is it possible to increase UPLOAD speed?
Nothing stopping you from having 2 lines with separate broadband packages especially if you already have a separate phone line.  Connection will be very similar to your current connection just only used by one device
JollyJed
Message 12 of 12
Ok brilliant mate thankyou, so call up BT and give the number for the phone line i want a broadband package on and im sorted? not sure if any more had to be done!
