Message 1 of 2
Is my noise margin slightly high?
Product name:Smart Hub
Serial number:+088044+1749008088
Firmware version:v0.09.05.11160-BT
Firmware Updated:Mon Feb 19 17:19:27 2018
Board version:01
DSL uptime:18 days,08 Hours21 Mins08 Secs
Data rate:9.995 Mbps / 54.995 Mbps
Maximum Data rate:27.859 Mbps / 97.905 Mbps
Noise margin:19.1 / 18.2
Line attenuation:5.0 / 7.4
Signal attenuation:4.9 / 7.4
Data sent / received:10.6 GB / 181.8 GB
Broadband username:bthomehub@btbroadband.com
BT Wi-fi:Activated
2.4 GHz wireless network name:BTHub6-G3HJ
2.4 GHz wireless channel:Automatic (Smart Wireless)
5 GHz wireless network name:BTHub6-G3HJ
5 GHz wireless channel:Automatic (Smart Wireless)
Wireless security:WPA2
Wireless mode:Mode 1
Firewall:Default
MAC address:EC:F4:51:B1:2D:38
Software variant:-
Boot loader:0.1.6-BT (Fri Sep 9 10:05:09 2016)
1 REPLY 1
Message 2 of 2
Re: Is my noise margin slightly high?
From your stats you are on infinity 1 55/10mb and as your attainable speed is far higher then it is normal for your noise margin to be above normal 6db
