Message 1 of 11
Is the open reach fibre modem gigabit?
10/100Mbs or 10/100/1000Mbs?
And if it is 10/100Mbs does that mean the BT HUB 5 combined router and modem would be faster?
10 REPLIES 10
Rottie
Expert
Message 2 of 11
Re: Is the open reach fibre modem gigabit?
Hi there,
The port is 10/100, as reported by my WNR3500L.
An old screenshot, but it illustrates what I'm saying (first line). Smiley Very Happy
Distinguished Expert
Message 3 of 11
So the Openreach ONT isn't capable of supporting speeds faster than 100Mbps?
Sorry, that's wrong. According to SIN 506, the ONT has 4 1Gb ports.
To say thanks for a helpful answer, please click the white star
Rottie
Expert
Message 4 of 11
Dead link, bud. 😞
Also, WRT the ONT, I'm assuming they're referring to the FTTP modem, as opposed to the FTTC one, as the throughput on FTTP is higher and would saturate a 10/100 port.
Message 5 of 11
Well, that is the link but they've changed the access path to get to it. So I removed it.
I thought we were talking about the ONT? "Openreach Fibre Modem" ?
Rottie
Expert
Message 6 of 11
LOL I thought we were talking about the FTTC variant, as that's the connection the OP has, according to his speedtest link. Smiley Surprised
Guru
Guru
Message 7 of 11
I believe the OP was talking about the Openreach VDSL modem as they stated about using the HH5 instead of it.
When it comes to FTTP on the other hand the Openreach Fibre ONT will of course need to be installed as well as the endusers router (be that a HH or a third party router).
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Rottie
Expert
Message 8 of 11
That's how I read the situation, too
Message 9 of 11
Ah ok. Note you still use a HH5 with FTTP 😉
Deathtrap3000
Recognised Expert
Message 10 of 11
All openreach vdsl modems are 10/100
All ONT's are gigabit.
Having a HH5 in place of the modem and router combo wont increase any speeds, theoretically anyway. You may find sync speeds vary slightly between all modems.
