syan123
Message 1 of 3
Is there a way?
Hi,
is there a way I could check if BT is planning to install a fttc cabinet in my area soon?
Perhaps on Planning page of the county site?
If anyone could, can you please check for:
GL3 4FL.
Thanks 😄
_______________________
Bart. K.
2 REPLIES 2
Guru
Guru
Message 2 of 3
Re: Is there a way?
Hi syan123,
Have you tried the BT Wholesale database with your landline number? http://dslchecker.bt.com/adsl
Having a look it looks like the majority of the propoerties within that postcode area are connnected to PCP40 on the BARNWOOD exchange.
There is an estimated date that PCP40 is to be upgraded and connected to a FTTC Dslam cabinet and ready on the 31-May-14
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
syan123
Message 3 of 3
Re: Is there a way?
You're right, but unfortunately those dates are liable to change as they are only estimates.
Those aren't the dates of installation but when all the work should be finished and infinity available for orders.
I have seen BT pull fibre optics around end of February but haven't seen them since.
Bart. K.
