Message 11 of 31
Re: Is there an issue with my line?
which master do you have
Message 12 of 31
5c Master socket.
Message 13 of 31
have you tried removing the faceplate and then connecting your filter to test socket and atry quiet line test again  this eliminates and internal wiring and master faceplate problems  best with corded phone ana a good filter
Message 14 of 31
See message 10.
Message 15 of 31
Indeed I did. Initially there was slight interference but - as previously advised - I restested with a different filter and it seemed quiet.
Noise seemed to be in play when testing via the face plate and  the modem conncted to its port.
Message 16 of 31
What do you mean by seemed quiet? It's either silent or not.
Message 17 of 31
So there was nosie on my first test but it seemed to go away - which I assume is not possible.
I'll run a test again tomorrow.
Message 18 of 31
It's entirely possible if the fault condition is intermittent and comes and goes.
Message 19 of 31
Sorry for the delay. I did the quiet line test again and there is an ever so slight sound of interference. However, this sound is not consistently there.
Message 20 of 31
So far you haven't confirmed you have removed the faceplate and connected (with a filter) to the test socket.
If you haven't yet then I suggest you do to see if it makes a difference.
