purple_kathryn
Message 1 of 5
Is there any difference between Superfast Fibre Plus & Superfast Fibre?
I just got an email about super fibre plus being in my area
but I already have super fibre & the speed seems to be the same Cat Frustrated
4 REPLIES 4
Zombie
Expert
Message 2 of 5
Re: Is there any difference between Superfast Fibre Plus & Superfast Fibre?
Fibre plus in a new product and it’s comes with a range of perks.
see this thread for more information. https://community.bt.com/t5/Bills-Packages/Introducing-BT-Plus/td-p/1848300
purple_kathryn
Message 3 of 5
cheers, i might actually consider it as my broadband price is going up next month
Zombie
Expert
Message 4 of 5
You’re welcome @purple_kathryn it may well be worth it, if you check your MYBT you may well have some offers for you to renew your contract with BT as I take it it’s coming to the end with you expecting a price rise. You might have an offer to renew for the same price you are currently paying so it’s worth checking it out.
purple_kathryn
Message 5 of 5
Thanks zombie!
