Danwilliams
Message 1 of 3
Is this normal ?
technical log says
Ppp1: The WAN DHCPv6 Client Processes has successfully been launched on Vlan 36
I haven’t set up any vlan or any networking like this ??
Is this on anyone else’s hub.
I’m running BT Smart Hub 6
Tags (1)
2 REPLIES 2
Sage
Sage
Message 2 of 3
Re: Is this normal
It's totally normal and nothing to worry about.
Danwilliams
Message 3 of 3
Re: Is this normal ?
Thank you
