ca-uk
Newbie
Message 1 of 3
Is this slowdown normal - seems like more than just crosstalk?
I've had Infinity for quite a while now - i'm on the unlimited one - i've had it for over a year, maybe even 18 months.
When i was activated then my sync rate was close to the top-end - about 76/18
However, i now only get 26/12
The online checker suggests i should still be getting a lot better? Nothing has changed inside my premises - i often see the BT bods playing in the cabinet and on the road, but no faults are showing up.
Exchange COSHAM is served by Cabinet 62
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High	Low	High	Low
FTTC Range A (Clean)	80	77.2	20	20	--	Available
FTTC Range B (Impacted)	80	69.8	20	17.7	--	Available
WBC ADSL 2+	Up to 2	--	1 to 3	Available
ADSL Max	Up to 1.5	--	0.5 to 2.5	Available
WBC Fixed Rate	1	--	--	Available
Other Offerings
FTTP on Demand	330	30	--	Available
Fibre Multicast	--	--	--	Available
Copper Multicast	--	--	--	Available
Any ideas on why my connection is now so slow?
2 REPLIES 2
Distinguished Guru
Message 2 of 3
Re: Is this slowdown normal - seems like more than just crosstalk?
Do you have a Homehub 5 ?
If not, I'll try again 🙂
Message 3 of 3
run btspeedtester and when first test completes then run diagnostic test and post results
btspeedtester
