redeye
Message 1 of 15
Is this usual behaviour when switching from infinity 1 to 2?
Hi all,
I've just switched back to infinity 2 after spending a year on infinty 1. My attainable rate from from my modem before the switch was 73024kb/s, now it's 62280kb/s.
Can anyone shine some light on why my line lost 10mb?
14 REPLIES 14
Message 2 of 15
Re: Is this usual behaviour when switching from infinity 1 to 2?
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
Message 3 of 15
@redeye wrote:
Hi all,
Probably because the upgrade resulted in a DLM reset which removed G.INP from your line. Hopefully DLM will re-instate G.INP in a week or two.
redeye
Message 4 of 15
Thanks,
Sorry no Home Hub 5, i've been using a HG612 with asus rt-n66u for 3 years.
here's some screen shots
before
after
redeye
Message 5 of 15
Thanks licquorice, I noticed g.inp gave me about 2mb when it went live a year or so back, but my attainable rate has never been this low.
Deathtrap3000
Recognised Expert
Message 6 of 15
Max attainable rates are estimates. Not a guarantee of what you would get if caps are lifted. Pretty normal behavior.
Message 7 of 15
As there doesn't appear to be anything in the Path 1 column it would seem to suggest G.INP has been removed. Can you telnet into the modem and post the output of  xdslcmd info --stats  which will confirm
Message 8 of 15
Max attainable rates are not estimates they are calculated from the individual line parameters, granted they may not be 100% accurate particularly with problematic lines, but they are pretty close.
Deathtrap3000
Recognised Expert
Message 9 of 15
If not 100% accurate, then surely the systems best guess or an estimate. Its never pretty close, at least in my experience.
Message 10 of 15
Are you talking about max attainable as reported by the modem or the checker figures? I'm talking about the modem figures.
