martpu
Expert
Message 1 of 9
Is www.vmspeed.com down?
Just got the following when trying to log into the site...
Access forbidden!
      You don't have permission to access the requested directory.    There is either no index document or the directory is read-protected.
If you think this is a server error, please contact the webmaster.
Error 403www.vmspeed.com Tue May  1 17:19:44 2012   Apache/2.2.10 (Linux/SUSE) Anyone getting the same?
________________________________________________________________________
You won't get to ride the racehorse...until you've ridden the mule.... - RogerB 13/04/2010
8 REPLIES 8
Message 2 of 9
Re: Is www.vmspeed.com down?
looks like its site is down
martpu
Expert
Message 3 of 9
Perhaps they have something against Infinity users using it?!
Message 4 of 9
just tried on adsl and it does not work there either
martpu
Expert
Message 5 of 9
Maybe BT as a whole then?!
Message 6 of 9
other isps as well are affected it is a server fault
martpu
Expert
Message 7 of 9
Cheers for finding out John.
lowei
Expert
Message 8 of 9
Its a speed test for virgin triallists, and is not going to be an official speed test site.
Moderator-Retired
Message 9 of 9
http://www.downforeveryoneorjustme.com is always a useful site for checking things like this.
Dean
BTCare Community Mod
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
