Paul-Ryan
Message 1 of 12
Issues with BT website & Upgrade to Fibre
The context here is my recent upgrade from standard broadband to fibre.  I hadn't previously been on Infinity, because it wasn't available for my address as we're on an Exchange Only (EO) connection.
BT sent me a letter a month ago saying that Fibre was now available to me.  I arranged for the upgrade to happen.  New Smart Hub has been installed & email notification received that we're now live with the new service.
Problem is that I haven't noticed any improvement - if anything there's been a degradaton in service in fact.
So, I've tried to check my line speed, to see what it actually is in practice.  I made use of the testing facility on the BT website, but although I get to the end ok it doesn't display the actual results.  Tried this on different devices but same outcome.  How/where do I find the test result itself?
Second issue: tried using the Webchat facility to rase this question, but it just closes as soon as I post on it.  Useless.
Finally: when aranging the upgrade, I asked the guy on the phone to double-check that the EO aspect wouldn't still be a limiting factor.  He assured me that it wouldn't be.   I'd be grateful for re-confirmation of this.   I've noticed on other posts that there can be a difference of view between BT and Openreach & I'd like to know if that might apply here.
11 REPLIES 11
Techwizz
Message 2 of 12
Re: Issues with BT website & Upgrade to Fibre
Can you post the line stats from the Hub? Go to http://192.168.1.254 - Advanced settings - Technical log.
Paul-Ryan
Message 3 of 12
Are these the entries you mean?
Data rate:9.999 Mbps / 48.838 Mbps
Maximum data rate:12.257 Mbps / 56.366 Mbps
Noise margin:8.4 / 5.8
Line attenuation:32.6 / 20.0
Signal attenuation:32.4 / 17.9
Distinguished Guru
Distinguished Guru
Message 4 of 12
You have indeed been upgraded giving you a connection speed of almost 49Mbps which should give you about  45Mbs in real terms.
Try THIS to test your speed and post the result.
Note: any speed test should be performed with a wired connection.
Message 5 of 12
go to advanced settings then technical log information and post results
enter your phone number and post results delete number    https://www.btwholesale.com/includes/adsl/main.html
from your stats you have a 48mb connection speed far greater than possible on adsl
Paul-Ryan
Message 6 of 12
reply to ppincp:
Have run this a few times.  Results are varying a lot, but typical one is along these lines:
Ping ms 40
Download Mbps 18.79
Upload Mbps 3.35
No, that's not with a wired connection, but it does allow me to say that these look much the the same as I was getting from similar on-line checkers before this upgrade.
Paul-Ryan
Message 7 of 12
Reply to imjolly:
Techwizz
Message 8 of 12
Your line is syncing below the handback threshold. Try connecting the Hub to the test socket and see if it increases the line rate.
Message 9 of 12
@Paul-Ryan wrote:
reply to ppincp:
Ping ms 40
Download Mbps 18.79
Upload Mbps 3.35
Your problem is your wifi, not your connection. Try splitting the bands and changing channels.
Message 10 of 12
