Distinguished Guru
Message 11 of 13
Re: Just had Infinity installed, upload seems very low.
As mentioned before, DLM only steps in on the first day when severe instability is detected like on your poor line.
If not, I'll try again 🙂
Guru
Message 12 of 13
No, the DLM isn't activated until day 2 It's very well documented.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
SteveBB
Message 13 of 13
So I restarted everything in the morning and my upload is higher now, so thanks for that tip. Is this as high as I will get? I paid for Infinity #2 but I guess those sorts of speeds are off the table.
 Download speedachieved during the test was - 22.16 Mbps
 For your connection, the acceptable range of speedsis 12 Mbps-22.91 Mbps .
 Additional Information:
 IP Profile for your line is - 22.91 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 6.51 Mbps
0 Mbps10 Mbps
Max Achievable Speed
Upload speed achieved during the test was - 6.51Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
