Message 11 of 12
Re: Just joined BT after house move and told Fibre essential is all that is available but not sure w
I thought I replied to this, but dont seem to see it.  Yes, im plugged directly into the master socket, but it appears an old one (MK3).
Message 12 of 12
@imjolly wrote:
As you are on a Huawei cab then if you can maintain a stable connection  then the DLM will hopefully reduce your noise margin down to about 3db which will give you a bit of a speed boost
Yeah, that was my first thought but the max data rate isn't much higher than the actual and should be predicated on the target SNRm i.e the first step down to 5dB, so not sure that 3dB is going to give much of a boost but fingers crossed it might do.
