NickH161
Message 1 of 3
Just upgraded to BT infinity 2 BThub6
What smart features do i need to turn off? I'm on sky Q and have BT TV but was told I need to turn things off in smart hub manager to get better connection?
2 REPLIES 2
Message 2 of 3
Re: Just upgraded to BT infinity 2 BThub6
NickH161
Message 3 of 3
@gg30340 wrote:
Make sure you turn off "smart setup" on the Homehub.
See link how to do that.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/what-is-smart-setup-on-the-bt-hub%3F-how-can-...
Some devices have a problem with the Homehub dual band having the same SSid (name). You should try splitting them.
See links
http://bt.custhelp.com/app/answers/detail/a_id/56419/~/how-do-i-split-my-bt-hubs-ssid-%28wireless-ne...
http://bt.custhelp.com/app/answers/detail/a_id/44798/~/i-have-problems-connecting-5ghz-and-dual-band...
Cheers thanks for your help
