Venomx
Expert
Message 1 of 35
Just upgraded to infinity 2
Does anything have to be physically changed for the upgrade from 1 to 2 ?
34 REPLIES 34
Venomx
Expert
Message 2 of 35
Re: Just upgraded to infinity 2
Finally got the email and all should be going live tomorrow.
Message 3 of 35
No it is just the removal of a software cap
Venomx
Expert
Message 4 of 35
Ok thanks
Venomx
Expert
Message 5 of 35
Should i restart the router or will the upgrade come through whilst it's on ?
Message 6 of 35
It'll happen automatically.
Can you post your hub stats?
Venomx
Expert
Message 7 of 35
BT Broadband /
BT Infinity /
BT Infinity 3 and 4:
BT Infinity
Firmware version:
SG4B10002244
Firmware updated:
29-Mar-2017
Serial number:
+084316+NQ70200220
Downstream sync speed:
60.69 Mbps
Upstream sync speed:
18.22 Mbps
Network uptime:
0 Days, 19 Hours 34 Minutes
System uptime:
0 Days, 19 Hours 36 Minutes
BT Wi-fi status:
Active
Message 8 of 35
You are on Infinity 2.
Venomx
Expert
Message 9 of 35
Message 10 of 35
Are you connected to the test socket?
