AlexTheLion
Message 1 of 7
LCAIM Ashton-in-Makerfield - When can i order
Hello,
FTCC date shows 30/9/12 my local cabinet has the new green box fitted and the http://www.superfast-openreach.co.uk/where-and-when/ shows Exchange is Accepting Orders.
Will it be anytime before the 30th or should i keep checking each day?
Postcode WN4 9RW
6 REPLIES 6
Message 2 of 7
Re: LCAIM Ashton-in-Makerfield - When can i order
just keep checking this checker it will let you know when your cabinet is live and you can order
http://www.dslchecker.bt.com/adsl/ADSLChecker.TelephoneNumberOutput
AlexTheLion
Message 3 of 7
Thanks, i've got that bookmarked on my phone.. So it could be literally any day?
Message 4 of 7
it could be days to months after the exchange goes live as cabinets are turned on in phases before yours goes live all you can do is wait
AlexTheLion
Message 5 of 7
Ordered today - install scheduled for Friday 8th February.. Great..
Message 6 of 7
pleased you can order hope all goes well for you
Guru
Message 7 of 7
Wow, You're very lucky with that quick install cgrats 🙂
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
