Curtos
Message 1 of 8
LOS Light is red
Help!!
My internet just went down and when I went and checked the white box the LOS light is red and I don't know what to do?!?
Tags (1)
7 REPLIES 7
Message 2 of 8
Re: LOS Light is red
I assume that you are on FTTP?
LOS= Loss of signal.
Most likely a fibre fault somewhere, or possibly a fibre modem fault.
Make sure that the fibre going into the modem is not been bent or damaged, and that the connector has not come loose.
All you can do is to report it as a fault.
Curtos
Message 3 of 8
there is some yellow stuff between the wire going to the modem and the connector
Message 4 of 8
It would be best to arrange a visit from Openreach, via the FTTP fault number.
I am not sure whay you mean by "yellow stuff"
Message 5 of 8
I'd hope it was an ethernet cable. :smileyvery-happy:
Curtos
Message 6 of 8
It's the one going to the optical input
Message 7 of 8
Right, not so familiar with FTTP, but I'd go with Keith's advice.
Message 8 of 8
Can you post a picture of it?
