freshest
Message 1 of 12
Latency Between Hops
Hey, I have quite a big problem going on with my hub 5 box where when im gaming I get extreme latency hops it might be a DLM issue or wiring, I have no idea what has caused it. I have some of the hops here Reply from 185.198.188.100: bytes=32 time=1029ms TTL=54 Reply from 216.58.204.14: bytes=32 time=181ms TTL=54 9 206 ms 45 ms 39 ms 185.198.188.1  9 901 ms 47 ms 30 ms 185.198.188.1  13 870 ms 18 ms 17 ms 108.170.246.193  As you can ee the start goes up to 9206, 9901 and then 13870 If i can get some assistance that would be great.
11 REPLIES 11
Distinguished Guru
Distinguished Guru
Message 2 of 12
Re: Latency Between Hops
Can you post a complete tracert?
freshest
Message 3 of 12
How do I get a complete tracert?
Distinguished Guru
Distinguished Guru
Message 4 of 12
Can you open a command prompt window? If so then just enter tracert followed by the destintion.
freshest
Message 5 of 12
Alrighty, I think this is it.
Spoiler
Running RC-RP Diagnostics test...
Retrieving system date and time.
16/12/2017
15:30
------- Ping/Traceroute to EU.FROSTGAMING.COM -------:
Pinging eu.frostgaming.com [185.198.188.98] with 32 bytes of data:
Reply from 185.198.188.98: bytes=32 time=16ms TTL=54
Reply from 185.198.188.98: bytes=32 time=17ms TTL=54
Ping statistics for 185.198.188.98:
Packets: Sent = 8, Received = 8, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 16ms, Maximum = 17ms, Average = 16ms
Tracing route to eu.frostgaming.com [185.198.188.98]
over a maximum of 30 hops:
1 1 ms 1 ms 2 ms BThomehub.home [192.168.1.254]
2 * * * Request timed out.
3 * * * Request timed out.
4 15 ms 15 ms 15 ms 31.55.185.188
5 19 ms 17 ms 17 ms core2-hu0-6-0-6.colindale.ukcore.bt.net [213.121.192.24]
6 17 ms 17 ms 16 ms 109.159.252.138
7 15 ms 15 ms 16 ms peer2-et-10-3-0.faraday.ukcore.bt.net [62.6.201.199]
8 16 ms 16 ms 16 ms linx-lon1.thn2.peering.clouvider.net [195.66.227.14]
10 18 ms 18 ms 17 ms 185.198.188.3
11 16 ms 16 ms 16 ms rev.srv3.eu.frostgaming.com [185.198.188.98]
Trace complete.
------- Ping/Traceroute to SERVER.REDCOUNTYRP.COM -------:
Pinging server.redcountyrp.com [185.198.188.100] with 32 bytes of data:
Reply from 185.198.188.100: bytes=32 time=18ms TTL=54
Reply from 185.198.188.100: bytes=32 time=17ms TTL=54
Reply from 185.198.188.100: bytes=32 time=47ms TTL=54
Ping statistics for 185.198.188.100:
Minimum = 17ms, Maximum = 1029ms, Average = 147ms
Tracing route to server.redcountyrp.com [185.198.188.100]
1 1 ms 1 ms 1 ms BThomehub.home [192.168.1.254]
4 18 ms 32 ms 37 ms 31.55.185.180
5 17 ms 17 ms 17 ms host213-121-192-8.ukcore.bt.net [213.121.192.8]
6 104 ms 17 ms 18 ms core3-hu0-8-0-0.faraday.ukcore.bt.net [195.99.127.36]
7 16 ms 17 ms 17 ms peer2-et-9-3-0.faraday.ukcore.bt.net [62.6.201.195]
8 17 ms 16 ms 17 ms linx-lon1.thn2.peering.clouvider.net [195.66.227.14]
10 18 ms 18 ms 22 ms 185.198.188.3
11 17 ms 17 ms 16 ms rev.srv5.eu.frostgaming.com [185.198.188.100]
Trace complete.
------- Ping/Traceroute to GOOGLE.COM -------:
Pinging google.com [216.58.204.14] with 32 bytes of data:
Reply from 216.58.204.14: bytes=32 time=17ms TTL=54
Ping statistics for 216.58.204.14:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 17ms, Maximum = 181ms, Average = 58ms
Tracing route to google.com [216.58.204.14]
4 16 ms 15 ms 15 ms 31.55.185.188
5 17 ms 16 ms 16 ms core2-hu0-0-0-1.colindale.ukcore.bt.net [195.99.127.136]
6 16 ms 16 ms 16 ms peer2-et3-1-4.slough.ukcore.bt.net [62.172.103.220]
7 334 ms 17 ms 16 ms 109.159.253.195
8 * * * Request timed out.
9 17 ms 17 ms 17 ms 64.233.175.154
10 319 ms 19 ms 19 ms 108.170.246.143
11 18 ms 18 ms 18 ms 216.239.57.227
12 19 ms 18 ms 18 ms 216.239.59.4
14 18 ms 17 ms 18 ms 108.170.238.145
15 17 ms 17 ms 17 ms lhr35s07-in-f14.1e100.net [216.58.204.14]
Trace complete.
IPconfig information:
Windows IP Configuration
Host Name . . . . . . . . . . . . : computer11-PC
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : home
Wireless LAN adapter Wireless Network Connection 11:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter #7
Physical Address. . . . . . . . . : 24-77-03-55-1E-59
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection 10:
Description . . . . . . . . . . . : Microsoft Virtual WiFi Miniport Adapter #6
Ethernet adapter Bluetooth Network Connection 4:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) #4
Physical Address. . . . . . . . . : 7C-E9-D3-C0-69-BE
Wireless LAN adapter Wireless Network Connection 9:
Connection-specific DNS Suffix . : home
Description . . . . . . . . . . . : Intel(R) Centrino(R) Ultimate-N 6300 AGN
Physical Address. . . . . . . . . : 24-77-03-55-1E-58
Link-local IPv6 Address . . . . . : fe80::6de2:da91:de52:156b%29(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.1.77(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 16 December 2017 15:23:14
Lease Expires . . . . . . . . . . : 17 December 2017 15:23:14
Default Gateway . . . . . . . . . : 192.168.1.254
DHCP Server . . . . . . . . . . . : 192.168.1.254
DHCPv6 IAID . . . . . . . . . . . : 572815107
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-F7-28-05-08-11-96-24-07-8C
DNS Servers . . . . . . . . . . . : 192.168.1.254
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Local Area Connection 4:
Description . . . . . . . . . . . : Intel(R) 82579LM Gigabit Network Connection #4
Physical Address. . . . . . . . . : D4-BE-D9-20-EC-53
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
DHCP Enabled. . . . . . . . . . . : No
Tunnel adapter isatap.home:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #6
*****Test Complete*****!
15:33
16/12/2017
freshest
Message 6 of 12
Bump
Distinguished Guru
Distinguished Guru
Message 7 of 12
Your tracerts show no problems.
BTW it's pointless bumping a thread, it won't get you an answer any quicker.
Liam_
Expert
Message 8 of 12
The timed out request is just a server configured not to respond to ping.
Tracing route to eu.frostgaming.com seems fine.
The increased latency on No. 9 206 ms 45 ms 39 ms 185.198.188.1 is outside the BT network and nothing you can do about that.
On the whole the timing to the game server looks normal.
Repeated pings to 108.170.246.143 returned 20ms from here so the longer time in your trace on the first ping is likely just a temporary glitch.
For information the 185.198.188.1 is in Holland, so again not a lot you can do.
freshest
Message 9 of 12
So is there a fix to this? Should I reset my box? What should I do.
Message 10 of 12
There is nothing you can do or that BT can do your connection is ok as you have already been told
