licquorice
Message 11 of 14
Re: Latency comparison - g.fast vs vdsl
Even if you had 2 BT lines to your house they wouldn't be identical. Even the physical location of a pair within a multi-pair cable can make a huge difference.  Every line is unique, you can't compare apples and oranges.
Stu_H
Message 12 of 14
It’s really hard to answer that but I game fine on a VDSL line using a HG612 modem and a number of routers aimed at controlling latency for better networking.
normally it’s the isp equipment that offers very little help to refine your network and a base pin means little if your network is the core of the latency and packet loss.
So for example I have a modest 55 down and a 13 up. My base ping is around 6ms. If I run PingPlotter and I’m using a Ubiquiti Dream Machine at the moment and turn off the QoS I get packet loss and spikes into and above 150ms. I turn on the QoS which is FQ Codel based, I limit the connection by 20% on both down and up and then test again my highest latency is just 8ms.
so I would strongly consider looking into another router to control your network as the chances are it’s your equipment rather than the line that’s the issue. If you change your isp the issues will follow you till you start looking at your own network.
oakserver
Message 13 of 14
@Stu_H That’s great and along the lines of what I was looking for. It proves to me that a ping of 6ms is possible from a VDSL line provided by BT and that gfast isn’t the only reason I see great latency with BT.
Although you did make an assumption that my kit was standard 😛 . I do use a Ubiquiti Edgerouter 4 now and the ping results were from the same router so that rules hardware differences out from my end 🙂
Stu_H
Message 14 of 14
So you are still dropping packets and seeing an increase in latency with the edge?
Install PingPlotter and test, don’t go by the sites that offer test like DSLreports but watch carefully using PingPlotter.
Record when you see the spikes or packet loss and see what was occurring on your network at that time ie was someone streaming or downloading or a video call.
Make sure the QoS is working as intended on the edge. I’ve noticed a bug on mine which has remained regardless of firmware or resets where altering the network channels causes the QoS on the upload to set at a different rate than my input. A reboot is required to correct this.
Try PingPlotter and see how you get on, if you saturate your connection and see dropped packets look at the graph to see it’s from your network.
Also look at your modem, I recently tried the Vigor 166 out and that created no end of latency so double check your modem as well.
