Message 1 of 26
Latency
Hi
I had an engineer out recently who done a geotech reset not sure what this is but it fixed my high ping well after 2 days the hub reset by itself and the latency has gone sky high and no matter if you reset the hub the latency issue is still high.The speeds are ok but the ping is poor,could you please help out how to solve
25 REPLIES 25
Message 2 of 26
Re: Latency
constantly resetting the hub/router will not help your conenction and more likely to make it worse  can you post stats from your router/hub
Message 3 of 26
Re: Latency
Hi ping is 50ms from 7 ms down I’d 38.5 up is 11
Message 4 of 26
Re: Latency
if you have a hh6 then go to advanced settings then technical log then admin and posr stats
Message 5 of 26
Re: Latency
What stats do you require?
Message 6 of 26
Re: Latency
if hh6 then as per my previous post    https://community.bt.com/t5/Announcements-Guides-Community/Broadband-Top-Tips-to-get-help-on-the-for...
Message 7 of 26
Re: Latency
I’ve got that but there are many stats on the log hence what ones do you require?
Message 8 of 26
Re: Latency
the stats look like ones on here https://community.bt.com/t5/BT-Infinity-Speed-Connection/BT-Infinity-2-5-mps/td-p/1809414/page/2
advanced settings then technical log then administration
Message 9 of 26
Re: Latency
Product name: BT Hub 6A
Serial number: +084316+NQ72384430
Firmware version: SG4B1000B316
Firmware updated: 06-Dec-2017
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 0 Days, 6 Hours 23 Minutes 44 Seconds
Data rate: 20.00 Mbps / 65.79 Mbps
Maximum data rate: 21289 / 78498
Noise margin: 6.9 dB / 6.1 dB
Line attenuation: 16.6 dB
Signal attenuation:
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Data sent / received: 345 MB Uploaded / 11980 MB Downloaded
Broadband username: bthomehub@btbroadband.com
BT Wi-fi: Active
2.4 GHz wireless network name: BTHub6-6WR9
2.4 GHz wireless channel: Smart (Channel 1)
5 GHz wireless network name: BTHub6-6WR9
5 GHz wireless channel: Smart (Channel 36)
Wireless security: WPA2 (Recommended)
Wireless mode: Mode 1
Firewall: On
MAC address: B8:EE:0E:AA:3B:F9
Software variant: -
Boot loader:
Message 10 of 26
Re: Latency
Are you using a wired or wireless connection ???
