Distinguished Guru
Distinguished Guru
Message 11 of 19
Re: Lease Line
Depends on what you are doing and how many in the household are doing. That 40Mb will be devided between everybody using it.
Mikee1
Message 12 of 19
Re: Lease Line
3 pcs, voip phone, 3 smart tv's, phones and tablets. Usual stuff for a house with 2 kids plus I work from home.
Message 13 of 19
Re: Lease Line
Did you need/use 350?
I’ve got an 80meg Service but never use anymore than 5 or 6 meg max.
Mikee1
Message 14 of 19
Re: Lease Line
Not sure. I just assume as I use so much connected equipment the more speed the better. Is there a way to check?
Message 15 of 19
Re: Lease Line
@Mikee1 wrote:
Thanks all. It was really to see if max speeds from a cabinet is different between residential and lease. Maybe I'll ask bt business. Sounds like it could be expensive.
Anyone think 40meg is OK. I'm used to 350meg.
If you are running a business, then you would have to go for a BT Business line, as you cannot use a residential line for commercial purposes.
BT Business do provide a better quality of service, with fewer connections allocated to each virtual path, so you are going to see a more consistent speed.
You also get a faster repair service.
The number of devices you describe, would have no issues on a 40Mb connection. The nature of IP, is that data is bursty in nature, and there are plenty of gaps, especially VOIP.
You might need to use a better router than BT supply, to avoid deterioration in VOIP calls.
I doubt you could actually achieve 350Mb throughput on your VM line, and by its nature, you would be lucky to get 5Mb upload speed, as their network was designed for delivering TV, which does not require much upload.
Distinguished Guru
Distinguished Guru
Message 16 of 19
Re: Lease Line
Gaming, web browsing, facebook etc use very little bandwidth. Streaming will push it up a bit dependng on quality 1080p, 720p etc.
Itis file transfers that'll push it, game updates etc.
Mikee1
Message 17 of 19
Re: Lease Line
I do stream movies a fair bit
Distinguished Guru
Distinguished Guru
Message 18 of 19
Re: Lease Line
"I doubt you could actually achieve 350Mb throughput on your VM line, and by its nature, you would be lucky to get 5Mb upload speed, as their network was designed for delivering TV, which does not require much upload."
Yes @Keith_Beddoe you are correct about the upload ATM it is abysmal for the download they are offering but to be fair for the past few years money has been invested in their network in preparation for DOCSIS 3.1 being deployed which will be a gamechanger.
As regards attaining 350Mb through a VM line there are many that do as VM overprovide most likely so they always score well with SamKnows.
Here's a screen grab of my friends connection who consistantly gets 55Mb from his 50Mb service.
The problem with VM is when congestion rears it's head, it takes months to resolve but expect all that to change when upgrades are complete and the switch to DOCSIS 3.1 happens.
MODS sorry to talk about another provider but I had to correct Kieth to be fair.
Distinguished Guru
Distinguished Guru
Message 19 of 19
Re: Lease Line
You should still be OK.
