Message 1 of 7
Less than minimum download speed on SUPERFAST FIBRE PLUS
Hi,
I changed to Superfast Fibre plus on the 22nd of August and now I'm not even getting the minimum download speed that I should get (50mbs). Before I was on Superfast Fibre and was getting 50mbs on the dot. As soon as I changed to Superfast Fibre Plus I started/currently getting avg of 40mbs. I am hard wired straight into my router as I use a desktop. Can anyone help?
Product name:
BT Hub 6A
Serial number:
+084316+NQ64155540
Firmware version:
SG4B1000B540
Firmware updated:
21-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
2 Days, 14 Hours 56 Minutes 13 Seconds
Data rate:
12.27 Mbps / 45.34 Mbps
Maximum data rate:
12268 / 55091
Noise margin:
6.1 dB / 6.4 dB
Line attenuation:
16.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
817931 MB Uploaded / 27073 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
LJCROSS
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
LJCROSS
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
AC:84:C9:B2:1B:0D
Software variant:
Boot loader:
7.33.1
6 REPLIES 6
Sage
Message 2 of 7
Re: Less than minimum download speed on SUPERFAST FIBRE PLUS
As has been posted on here many times already, the upgrade to Plus has reset DLM. Give it 14 days for G.INP to be re-invoked and your speed should be back up.
Any problem after then get back.
Message 3 of 7
Ok so after roperting the issue on here I decided to just call BT and make them aware of the issue I was having so they had it on record. They did try "Tests" which seemed to make my connection worse for a while so advised they would send out an Engineer. I advised that I would rather monitor the connection to see if it improves over the 14 days. I did advise them of G.inp and DLM but they didn't know what I was talking about.
Last night I checked my connection and it had been online for 13 days and so many hours, Tonight I checked it and its now back to 0 days and 18 hours :(. My connection is still lower than minimum. Is there anything else I can do or ask BT to help with?
Strangely tonight I also noticed my mobile wasn't on the wifi and my SSID wasn't showing. I browsed to the router IP to find out that the SSID had changed to Broadcom_02263820 and a completely different WiFi password. Any clue why this has happened?
Jamie
Message 4 of 7
can you repost the router stats please
Message 5 of 7
Product name:
BT Hub 6A
Serial number:
+084316+NQ64155540
Firmware version:
SG4B1000B540
Firmware updated:
21-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
1 Days, 10 Hours 59 Minutes 59 Seconds
Data rate:
12.18 Mbps / 45.37 Mbps
Maximum data rate:
12175 / 55271
Noise margin:
6.1 dB / 6.5 dB
Line attenuation:
16.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
23191 MB Uploaded / 8291 MB Downloaded
Broadband username:
BT Wi-fi:
Active
LJCROSS
Smart (Channel 11)
LJCROSS-5
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
AC:84:C9:B2:1B:0D
Software variant:
Boot loader:
7.33.1
Message 6 of 7
Your speed from last stats is very similar to original stats with attainable at bottom of estimate and connection speed low
Have you tried using the test socket with a filter even though you may currently use a filtered master socket this should be your best connection and eliminates your internal wiring as causing a problem
Can you repost to see if any difference
Message 7 of 7
"Have you tried using the test socket with a filter even though you may currently use a filtered master socket this should be your best connection and eliminates your internal wiring as causing a problem"
What does this mean sorry?
Before I changed my contract I was on a 50mbs connection and when I tested my connection I got 50mbs. Don't see it being a wiring issue as nothing has changed.
