Message 1 of 2
Lights on fibre modem
Hi
Is there a way to switch off the status lights on the BT fibre modem.
I can (and have) switched off the hub lights - they now only come on if there is a problem.
I would like to do the same for the modem as the flashing leds light up the room.   I really don’t want to resort to having to tape over them!
thanks
1 REPLY 1
Message 2 of 2
Re: Lights on fibre modem
No, there is no customer access to the ONT. Black tape I'm afraid.
