Octopus16
Message 1 of 18
Line Attenuation
My line attenuation has jumped from 26dB to 45.2dB... speed down to what I used to have on ADSL 2+! My line attenuation is also the same as what I had on ADSL 2+!
This happened right after some Openreach engineers were working in the BT manhole across the road. Could it be that I've been moved down to ADSL 2+ because of instability?
Product name:
BT Hub 6A
Serial number:
+084316+NQ94590721
Firmware version:
SG4B1000E020
Firmware updated:
20-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
0 Days, 2 Hours 49 Minutes 5 Seconds
Data rate:
0.96 Mbps / 19.25 Mbps
Maximum data rate:
1956 / 21572
Noise margin:
6.1 dB / 3.1 dB
Line attenuation:
45.2 dB
Signal attenuation:
29.2 dB / 45.2 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
445 MB Uploaded / 2 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BT
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
BT
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
5C:B1:3E:16:4A:1B
Software variant:
Boot loader:
0.48.8-sec
17 REPLIES 17
pippincp
Message 2 of 18
Re: Line Attenuation
G993.2 annex B - the VDSL2 specification. So no, you haven't been reverted to ADSL.
Octopus16
Message 3 of 18
Thank you. Do you know any other reason that my line attenuation has jumped from 26dB to 45dB?
pippincp
Message 4 of 18
Offhand and not being to test your line myself, no.
If its not causing you problems don't worry about it.
Fulmar
Message 5 of 18
I note that your hub's firmware was updated 5 days before your post to version SG4B1000E020. After the same upgrade my speed dropped from 38+ Mbps to 26 Mbps and the line attenuation leapt from 26 dB to 45 dB ... similar to your experience? (see my post at https://community.bt.com/t5/BT-Fibre-broadband/Higher-line-attenuation-amp-amp-lower-speed-after-BT-...).  I wonder if that's a coincidence or if there is something in that firmware upgrade that has affected the line characteristics...?
Octopus16
Message 6 of 18
It must be firmware, I have recently upgraded to a third party TP-Link router.
All of my problems are solved and I am now getting 38mb/s, faster than ever. Sometimes, speed peaks at 44 mb/s.
Line attenuation now 17.9db, down from 45+.
I really recommend it, 2 minute set up and modem is built in.
I was getting frustrated with BT problems, but it is not the networks' fault... it is their hubs!
 before new router
After new router... TP link
Fulmar
Message 7 of 18
Thanks for that info, Octopus16 - that is strong circumstantial evidence that the upgrade is to blame and that the "true" line attenuation and speed that may be achieved, is really unchanged...
Octopus16
Message 8 of 18
Plus, I'm using my old BT Smart Hub as an access point!
prasadm
Message 9 of 18
Does a new router help if the connection is somehow appear banded ? Banding is done not on the router is it ? Or will it reset the connection from scratch ?
jeb0007
Message 10 of 18
That firmware update has caused these issues.  There are quite a few on here with the same problem ( which I also have )
Maybe, just maybe is was designed to throttle back the whole BT  band width to allow more users working from home to get access during this Covid-19 issue..   Who knows, but when that update happened things changed for lots of people and depending how good your speed was before you may not of noticed it, but lots have...
