prasadm
Message 11 of 18
Re: Line Attenuation
So long as my work does not suffer, I am prepared to give the benefit of doubt to BT however annoying that maybe, until this crisis blows over.  Lets hope things get back to normal.
Stay safe everybody 👍
Octopus16
Message 12 of 18
Update:
  • My new TP-Link router hasn't had any ISP updates but my speed has dropped to what it was on the Smart Hub.
  • I'm getting more than two drop-outs an hour and it is really affecting working from home etc.
I've changed to using my Vodafone 4G+ data service and I've found it stable & reliable and that's in a pretty rural area! 😉
pippincp
Sage
Message 13 of 18
Check for line noise, 17070 option 2, best with corded phone.
Can you post the connection stats from the TP-link.
Octopus16
Message 14 of 18
A constant hiss on the line... TP-Link router solved problems, now they're back...
I have run all shielded cabling to the router, it still drops out every couple of hours...
pd123
Message 15 of 18
prasadm
Message 16 of 18
In my case, the Downlink attenuation value fluctuated quite a bit for sometime in April and then it stabilised . I am not sure if the issues I had with the broadband speed were because of the attenuation, as subsequent monitoring of the data does not suggest attenuation values as seen in my HH6 has a direct bearing on the speed although I am speculating. I did collect data over a month when the broadband speed started fluctuating quite a bit and dropped to a level which I couldn't work with.  Please see the attached graph. The data is collected every 2 minutes or so. Prior to 29th April, the speed was also fluctuating quite a bit as you can see in the initial part of the graph, and since then DLM did stabilise the line, and brought it back to my normal levels. Yes, took a while. But the Downlink Attenuation as you can see kept fluctuating quite a bit since then. It is now stable too. The Uplink attenuation did not seem to have fluctuated like this. As I said  in my case the line is stable now with same firmware.
ps: the data in the graph is taken from router manually and painfully, no hacking /unlocking involved if anyone wonders
azual
Message 17 of 18
Has anyone found a fix for this? Just got the update on 23rd Nov and I get crappy connection sometimes now.
TEREU5
Message 18 of 18
I did get update of firmware on 21 -Dec (HH6) and connection for some reason is pretty poor now ...
