imjolly
Message 51 of 79
Re: Line Speed
are you able to run btspeedtester again but then after first test completes run diagnostoc test and post results  must be done with ethernet conenction not wireless if problems try different browser - edge or chrome
you never said if previous btspeedtester results were with wired connection
** edited**  thanks @pippincp
pippincp
Message 52 of 79
Re: Line Speed
I think @imjolly means not wireless.
PaulWilson67
Message 53 of 79
Re: Line Speed
Yes my laptop was plugged into my modem, not WiFi
RogerB
Guru
Message 54 of 79
Re: Line Speed
Do not attempt to use the SNR setting in the router, it should be left at default -1
Check to see if your DSL settings look like this:
licquorice
Message 55 of 79
Re: Line Speed
@RogerB The OP is syncing at maximum rate with a massive attainable rate, any problem is either false reading from the speedtester or congestion.
PaulWilson67
Message 56 of 79
Re: Line Speed
Wont get a chance to look at it until Friday, will keep you posted.
Again thanks for the help.
RogerB
Guru
Message 57 of 79
Re: Line Speed
@licquoricewrote:
@RogerBThe OP is syncing at maximum rate with a massive attainable rate, any problem is either false reading from the speedtester or congestion.
So it seems ... but if the RAP profile from the BRAS has failed, the msan port won't see a line profile rate to run to, and stick at its previous setting. He went from 10mbits ADSL and is now only throughputting at 13-15mbits, and that could be because ptm packet transfer is more efficient than atm. But the port rate isn't set. I could understand your view re- the throughput if it was about 25% low .... but technically his hasn't moved, apart from changing packet transmission type. atm to ptm. Both BRAS, RAMBO and RAP profiles have to set (automatically) for the port to see the speed. (may need intervention if it doesn't clear on its own)  ... and the speedtest data won't report one.
Maybe an NCAS or OSS system failure much like used to happen with new Max to ADSL connections. Even though it's automated ... sh1te happens.
(and why I told him to switch it off and disconnect for 24 hours)
licquorice
Message 58 of 79
Re: Line Speed
What are you talking about, the OP was previously on ADSL from the MSAN, he is now on VDSL from the DSLAM in the cabinet.
The problem is either congestion or speedtester error.
RogerB
Guru
Message 59 of 79
Re: Line Speed
kitz.co.uk/adsl/DLM_system.htm#RAP
licquorice
Message 60 of 79
Re: Line Speed
But you are implying that the OP is still connected to the same equipment as before and is stuck on his ADSL IP profile, that is simply not the case, he is now on a completely different circuit connected to different equipment.
