Heavenswake
Message 1 of 2
Line attenuation? can someone tell me what it is pls
hey all
just curious, whats the Line attenuation? is it something to do with the distance to the cab?
sorry if this has been explained b4?
is it something to do with like the signal strength based on distance?
reason im asking is that after the engineer came on the 11/08 my Line attenuation is now 18.8
where as b4 the engineer came it was 19.0 as u can verify from my original post
https://community.bt.com/t5/BT-Infinity-Speed-Connection/Noise-Margin-clearifaction-pls/m-p/1325575#...
just curious, now im on vdsl theres alot of new things to understand heh
virgin was so much simpler. plug and play never had any problem with virgin guessing i was lucky. if it wasnt for the money im saving id never of left them heh
tnks in advance
1 REPLY 1
Message 2 of 2
Re: Line attenuation? can someone tell me what it is pls
that sort of attenuation change is perfectly normal throughout the day and yes your attenuation is controlled by your line length and quality
