mrgoldfish1
Message 1 of 4
Line attenuation
My Line attenuation has changed from 17 to 28.7. My download speed has went from 67 to 44, can anyone suggest why this has happened ? I’ve had a stable line for about 4 years with no real issues.
Product name:
BT Hub 6A
Serial number:
+084316+NQ83755283
Firmware version:
SG4B1000E020
Firmware updated:
13-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
3 Days, 7 Hours 40 Minutes 20 Seconds
Data rate:
12.00 Mbps / 50.62 Mbps
Maximum data rate:
18672 / 52887
Noise margin:
10 dB / 6.4 dB
Line attenuation:
28.7 dB
Signal attenuation:
20.8 dB / 28.7 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
28 GB Uploaded / 135 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-3XGK
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-3XGK
5 GHz wireless channel:
Smart (Channel 44)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
3 REPLIES 3
pippincp
Sage
Message 2 of 4
Re: Line attenuation
mrgoldfish1
Message 3 of 4
I guess it’s a botched firmware upgrade then. I’ve got a unlocked openreach modem but the 6a is not compatible. I think it’s a case for waiting for new firmware. Do you think bt know about this and actually are looking for a fix?
pippincp
Sage
Message 4 of 4
I'm sure they'll be aware but how long it will take them to sort out is anyone's guess.
