Brandscill
Message 21 of 31
Re: Line dropping every couple of days
Just logged into my account and ran diagnostics for the Landline as girlfriend told me there was no dial tone.
It's found a fault external to our building apparently and they'll send an engineer. No appointment needed as it's not within the house.
Shall see where this goes then!
Brandscill
Message 22 of 31
Engineer came out, couldn't find a fault outside of the property but said he detected a fault 53ft down the line. Get no dial tone when connected to the test socket, ordered another phone to test with (because I don't want to be charged £130 for a fauly phone!) and then will call BT back to arrange for an appointment again.
Text the engineer and he reckons it's somewhere between the junction box and the master socket.
herrbohnen
Message 23 of 31
My broandband speed is always  about 50 Mb/s as I live fairly close to the exchange  , it always tests "good" but my browsing speed is very often really slow and laggy . my CPU use is about 5% and the PC is connected to the smart hub 6 with a CAT5 cable
Brandscill
Message 24 of 31
Okay new phone did not work either!
Engineer coming next Wednesday afternoon
Brandscill
Message 25 of 31
Engineer been, fixed the phone fault.
Noise margins gone up, speeds improved?
Message 26 of 31
looking far better now
Brandscill
Message 27 of 31
Despite the fact the noise margin is very high? In earlier post you said 6 is normal.
Message 28 of 31
The noise margin is high because you have some 'head room' , you are syncing at maximum speed but your possible speed is beyond the Infinity2 cap.
If you could sync at 90M your noise margin would be 6dB.
XRaySpeX
Recognised Expert
Message 29 of 31
The NMs can't go any lower. Both Down & Up sync speeds are hitting their 80/20 Meg caps, so the NM has to rise.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Brandscill
Message 30 of 31
I see, thanks for clearing that up!
Is there any good technical explainer online I can read up on?
