XRaySpeX
Recognised Expert
Message 11 of 31
Re: Line dropping every couple of days
What does BT Broadband Availability Checker estimate for your phone number? Post just the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number, use the Address Checker, not the Postcode Checker.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Brandscill
Message 12 of 31
Unfortunately I can't stop it as I'm away so I need to wait for someone else to move the router.
If I move it, and it stabilises, will it recover by itself or will it need BT intervention?
Brandscill
Message 13 of 31
Here are the stats.
Also noise margin now showing at 9.8/8.6. Which one is upload and which is download? Still not moved to test socket yet.
Message 14 of 31
from the way you posted stats earlier - up left down right
Brandscill
Message 15 of 31
Thanks.
Do you know if things will improve by themselves (speed and noise wise) if I move it and things get stable. Or will I need to call BT?
Message 16 of 31
you won't know until you are connected to test socket and post stats
Brandscill
Message 17 of 31
Okay thanks. Will hopefully have stats tonight.
Brandscill
Message 18 of 31
Okay,
So the person moved it back to the primary socket, not the test socket. Things got too complicated explaining over the phone.
Here are the new stats - what are the thoughts?
Sage
Sage
Message 19 of 31
Without the stats when connected to the test socket impossible to comment. I know it maybe difficult to organise but a test socket connection rules out any internal problem.
Brandscill
Message 20 of 31
Fair enough, I'll have to do it next Wednesday when I get back as it was bad enough just getting it moved Smiley Frustrated.
Given a previous poster in this thread said 6db was the target, surely this shows an improvement?
