CameronMac32
Message 1 of 7
Line max speed
I'm on Infinity 2 package and was wondering is this the max speed my line can get?
6 REPLIES 6
imjolly
Message 2 of 7
Re: Line max speed
You may get a bit more speed if DLM activates G.INP and noise margin goes down to 3db giving increase nearer attainable
CameronMac32
Message 3 of 7
Re: Line max speed
Do you know how to get DLM to activate G.INP and reduce the noise margin to 3db, do I need to contact BT?
imjolly
Message 4 of 7
Re: Line max speed
It's automatic not manual and you just need to maintain a stable connection and it may get activated
CameronMac32
Message 5 of 7
Re: Line max speed
I have the HH5 Type B router which restarts itself every 10-14 days which I have looked online and it seems to be a bug, will the restart affect my line?
pippincp
Sage
Message 6 of 7
Re: Line max speed
The restart being that far apart will have no effect on DLM
CameronMac32
Message 7 of 7
Re: Line max speed
Other than the router restarts, my line has been stable with no disconnects but no G.INP or noise margin reduce on my line Smiley Sad
