D00B
Message 1 of 22
Line speed and attenuation
Hi, I've had my line repaired today after being without service since the 17th January.
I have checked my connection speed on the HH5 and can see it is synced at a slower speed than it should be.
I have googled the best line attenuation and noise margin, but get different answers. Some say higher the better, others say lower.
Should I be expecting more from my connection with these results.....?
Any help would be great.
21 REPLIES 21
pippincp
Sage
Message 2 of 22
Re: Line speed and attenuation
Why's your hub only been up for 1 1/2 hrs?
D00B
Message 3 of 22
This was taken about 5pm, i've only just got around to posting it. 1 1/2hrs is A LOT better than it has been recently, noise on the line before today was shocking. I was not staying connected for longer than a few minutes each time.
imjolly
Message 4 of 22
Are you on infinity or adsl/copper
D00B
Message 5 of 22
FTTC if that helps any, although the package i'm on is 'faster broadband' because of distance
pippincp
Sage
Message 6 of 22
Bit of a misnomer that @imjolly as VDSL is also copper.
Op have you tried connecting to the test socket with a filter? Is there any noise on your line 17070 option 2, any noise report a line fault con't mention broadband.
imjolly
Message 7 of 22
@pippincp  Must have been clear enough as I got the answer
imjolly
Message 8 of 22
Can you enter phone number and post results. Remember delete number https://www.btwholesale.com/includes/adsl/adsl.htm
D00B
Message 9 of 22
pippincp
Sage
Message 10 of 22
Did you see post 3 @imjolly?
