bikeit
Message 311 of 314
Re: List of Routers to replace Home Hub 3.
Guys dont mean to jump in here but im currently using a HH3 which is v bad wireless signal in the house if BT where to give me a new HH5  Free should i take it, also is it easy to set up?
CoopsV8
Newbie
Message 312 of 314
Hi Guys,
what a long thread lol.
Right on my 2nd HH3 from BT, same as last time, needs rebooting every so often,
can't run two gaming consloes on the same game online etc, works ok for a while after a reset then back to the same thing again,
Have rad numerous posts online that the BT HH3 is not really up to the job,
my HH3 plugs direct into the phone socket via a filter, have changed the filter to differnt brands a few times but sdame issue so think that rules the filters out,
Is this the router i need???
  • Sorry, this item is not available in
  • Image not available
NETGEAR DGND3700-100UKS N600   ?????
or can you recommend any others, its mainly for my kids gaming side as they are fed up now not being able to get online on the same game,
Regards Tony.
Message 313 of 314
Yep, that will do just fine.
bikeit
Message 314 of 314
I got the HH5 for free and its a lot better in all aspects than the HH3, using it now for about four months and never had one dropped connection.
