suchyok
Message 1 of 20
Locked max speed
Hi
I have blocked max speed regardless of the time when I use the internet.
I contacted the technical department, they said they fixed it, but they did not do it. As we explain that there is a blockage, it is said that it is ok.
Is someone who can unlock it?
I have a guaranteed 52Mbps.
example
 11/10/2018  http://www.speedtest.net/result/7708881283
28/09/2018   http://www.speedtest.net/result/7673405652
http://www.speedtest.net/result/7708902684
My speed is max 45Mbps
Reagrds
19 REPLIES 19
pippincp
Sage
Message 2 of 20
Re: Locked max speed
Can you post the connection stats from the hub.
HH6 Advanced settings/technical log.
HH5 Troubleshooting/helpdesk.
imjolly
Message 3 of 20
enter your phone number and post results  remember delete number but leave exchange and cab  https://www.btwholesale.com/includes/adsl/main.html
post here rather than links as make easier to follow
suchyok
Message 4 of 20
suchyok
Message 5 of 20
Product name:
BT Hub 6A
Firmware version:
SG4B1000B540
Firmware updated:
11-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 9 Hours 7 Minutes 26 Seconds
Data rate:
20.00 Mbps / 46.65 Mbps
Maximum data rate:
21612 / 60203
Noise margin:
6.4 dB / 4.8 dB
Line attenuation:
16.5 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
2494 MB Uploaded / 11164 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BT5
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BT5-5
5 GHz wireless channel:
Smart (Channel 48)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 2
Firewall:
On
Software variant:
Boot loader:
9.2.0
imjolly
Message 6 of 20
connection time is only 9hrs is that due to router dropping connection or manual reset?
check for line noise  dial 17070 option 2  should be silent and best with corded phone
are you currently using the test socket with a filter, even if you have a filtered master socket, to see if that helps improve connection by eliminating faceplate and internal wiring
suchyok
Message 7 of 20
I apologize for the delay, but I do not have a phone and have to borrow. I bought a new telephone cable and a new microfilter. Test are ok with front faceplate or without are same.
All my troubles began after the renewal of the contract.
When I talked to a technician from BT, he told me that the speed should be about 68Mbps because I live about 500m from the cabin.
It is annoying that I was told that the problem was solved by the technician. And I have a guaranteed 52Mbps.
The results below from today are local and some European capitals with two different IPs.
Product name:
BT Hub 6A
Serial number:
+084319+NQ73967763
Firmware version:
SG4B1000B540
Firmware updated:
11-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 16 Minutes 35 Seconds
Data rate:
20.00 Mbps / 43.74 Mbps
Maximum data rate:
22108 / 58848
Noise margin:
6.4 dB / 6.2 dB
Line attenuation:
16.4 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
12998 MB Uploaded / 87534 MB Downloaded
Broadband username:
BT Wi-fi:
Active
BT5
Smart (Channel 1)
BT5-5
Smart (Channel 48)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 2
Firewall:
On
MAC address:
Software variant:
Boot loader:
9.2.0
Regards
imjolly
Message 8 of 20
are you currently using the test socket witha filter as that should be your best connection  if not can you conenct to test socket can you post new stats and see if the overall stats show any improvement   are you connecting direct to test without need for extension cable
if you have extension phone sockets then when in test socket there you do not get a dial tone at extensions
suchyok
Message 9 of 20
All tests made via test socket after put faceplate back is exactly same results.
imjolly
Message 10 of 20
i was hoping you still in test socket and could post stats   Your connection speed may not have improved but your attainable and noise margin could have changed
