mallybee
Message 1 of 7
Losing speed from master socket to Smart hub
Hi.
I've had a complaint logged in relation to slow speed since the start of September and have had over 30 phone calls to or from them.
I've had 3 engineers to my home and and they have all have said that I am getting 15Mbps to my master socket but from the smart hub I am only getting 9Mbps as shown on the router status page.  This is with one laptop connected via ethernet.
I've had a new router and it's exactly the same.
BT said that they have never heard of this issue and can't offer any more support as I am getting over my minimum guaranteed speed of 7Mbps.
Has anyone else had this issue?
Thank you in advance for your help.
Mally.
6 REPLIES 6
Devon_Dave
Distinguished Guru
Message 2 of 7
Re: Losing speed from master socket to Smart hub
Have you replaced the hub?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
mallybee
Message 3 of 7
Thanks for your reply.
Yes I've had a new router and it exactly the same.
imjolly
Message 4 of 7
Can you post hub stats. Advanced settings then technical log information
enter your phone number and post results remember delete number   https://www.dslchecker.bt.com/adsl/adslchecker.welcome
mallybee
Message 5 of 7
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High
Low
High
Low
VDSL Range A (Clean)
18.6
11.3
0.8
0.8
8.8
Available
Available
VDSL Range B (Impacted)
18.5
10
0.5
1.2
7.1
Available
Available
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand
330
30
Available
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+
Up to 2
1 to 3
Available
ADSL Max
Up to 0.5
0.25 to 1.5
Available
WBC Fixed Rate
0.5
Available
Fixed Rate
0.5
Available
Observed Speeds
VDSL
Max Observed Downstream Speed (Mbps)
9.01
Max Upstream Observed Speed (Mbps)
0.79
Observed Date
2019-11-06
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Premise environment
Status
Bridge Tap
U
VRI
N
NTEFaceplate
N
Last Test Date
05-11-2019
imjolly
Message 6 of 7
which exchange and cab are you on. Was at top of checker results
mallybee
Message 7 of 7
Exchange WELLFIELD is served by Cabinet 7
