Bicceh
Message 1 of 6
Loss of about 20mb downstream over night
Hi All,
I was experiencing some issues over the last couple of days in regards to line drops so i contacted BT to report it. Initially, i was using the home hub 3 however they asked me to install the home hub 5 i recieved when i moved home so i did. They also mentioned that they've 'done some fixes' to my line and everything should now be ok.
So far this morning now drops, but i've noticed a big drop in total speed. I've copied my hub info below and also the adsl checker:
1. Product Name: HomeHub5
2. Serial number: +076286+1533003725
3. Firmware version: v0.07.05.0A13-BT (Type B) Last updated 25/2/2016
4. Board version: 01
5. VDSL uptime: 0 days, 13:53:10
6. Data Rate: 10000 / 73998
7. Maximum Data Rate: 35386 / 99705
8. Noise Margin: 23.6 / 12.4
9. Line Attenuation: 11.0 / 11.5
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 193.3 MB / 5.5 GB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4GHz wireless network/SSID: BTHub5-H7KR
15. 2.4GHz wireless connections: Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4GHz wireless security: WPA2 Only (Recommended)
17. 2.4GHz wireless channel: 10
18. 5GHz wireless network/SSID: BTHub5-H7KR
19. 5GHz wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5GHz wireless security: WPA2 Only (Recommended)
21. 5GHz wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 5c:dc:96:c9:71:37
24. Software variant: - 25. Boot loader: 0.5.1-BT (Wed Nov 12 11:52:05 2014)
ADSL Checker: http://imgur.com/xHoC8pT
If anyone has any ideas on how to can improve it then let me know 🙂
Many thanks!
5 REPLIES 5
Message 2 of 6
Re: Loss of about 20mb downstream over night
Can you use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
Message 3 of 6
The drops in your connection have cause DLM to increase your noise margin to offer some additional protection to try and combat whatever it was that was causing the drops. If thr hub was the problem and the line remains stable with the new router, DLM will allow the noise margin to drop and the speed to increase. Be aware that this can take a couple of weeks to happen though.
You're possibly on the 37-74meg downstream band and the 0.128-10meg band for the upstream due to the disconnections.
Again, this will be removed if your line remains stable but as before, could take a few weeks.
Message 4 of 6
John - I assume the title loss of 20meg is relating to the difference in max attainable speed
Bicceh
Message 5 of 6
Thankyou both for the posts.
Results of the test is below:
Download Speed: 66.9
Upload Speed: 8.9
Latency: 20ms
That's already different to earlier today. Initially i was getting around 75mb and this was constant 24/7 uptime for about 3 weeks. Last night it was at about 45mb. this morning 55mb and now 66mb.
I presume it's what Webby was saying and it should balance itself out over time?
Message 6 of 6
Yeah. Give is a few weeks and providing the connection is stable, the speed will return.
